Activity › Forums › Adobe After Effects › correcting luminance flickering on old B&W cine footage??
  • correcting luminance flickering on old B&W cine footage??
    Posted by Ali Brown on July 28, 2006 at 1:59 pm
    Hi guys,
    Urgent help needed if you can pleeease! I have just been given some old black and white cine footage (on digi beta) and been asked to stop the luminance flicker, basically the producer thinks the constant changing of colour contrast will be annoying to the viewer. Does anyone out there know of a filter or manual way of removing this contrast changing flicker so it is a constant luminance/colour??
    Many thanks in advance!
    Ali
    Ali Brown replied 20 years, 2 months ago 2 Members · 2 Replies
  • Mylenium
    July 28, 2006 at 4:40 pm
    Give the Auto-Brightness/ Auto-Contrast/ Auto-Color effects a try they will not completely compensate, but it should be much more pleasant. Other than that apply a Levels effect and counter-animate the Gamma to compensate for the variations. Camera flicker is repetitive, so with the initial timing in place you could then simply apply a loopOut(“cycle”,0) expression to the Gamma control and it will repeat the cycle across the entire length of the footage.
    Mylenium
    [Pour Myl
  • Ali Brown
    July 28, 2006 at 4:56 pm
    No its footage from an old cine film shot in the early 1900s unfortunately.
