Activity Forums VEGAS Pro Correcting GoPro Hero3 Protune files to match DSLR footage
  • Correcting GoPro Hero3 Protune files to match DSLR footage
    Posted by Scott Simpson on December 10, 2013 at 6:43 pm
    Shot a pro wrestling show recently with half a dozen Canon DLSR cameras all white-balanced to the same card, all using the Standard picture style. I’m pleased enough with the images.
    Also shot with a GoPro Hero3 Black mounted to the ringpost. Pleased enough with the field of view, detail, etc.
    Problem I’m having is that the color and levels are a total mismatch between the GoPro and the Canon cameras. The GoPro footage isoverall orangey, and the blacks aren’t black (waveform monitor confirms that).
    I’ve tried using the Sony Color Match plugin, tried the Sony White Balance plugin (tried both a photo of the white card and a ‘white’ in the image, no love), tried tweaking with Levels, even took a quick pass at it with the Color Corrector, and nothing really gets me close enough to have it match.
    The GoPro was set to record in Protune mode, which I’m no expert on.
    My workflow so far:
    – copied original .mp4 files from the GoPro card
    – transcoded in GoPro Studio application to ‘edit-friendly’ .avi files in high quality mode
    – dropped those converted .avi files onto the timeline in Vegas 12.
    Recommendations?
    Canadian broadcaster brought up in analog, living in digital. Radio’s my career, audio-video-photography are hobbies that make a buck here and there.
    Scott Simpson replied 12 years, 8 months ago 2 Members · 5 Replies
  • Norman Black
    December 10, 2013 at 11:59 pm
    GoPro Protune will require a number of edits to get to a normal/typical visual look. Protune is designed with a log curve so it is very flat in contrast. Also saturation is low, sharpening is low, and noise reduction is lower than standard GoPro output.
    Canon standard picture style is deigned to be a nice contrasty final look, unlike GoPro protune.
    In trying to use the Sony colormatch FX you might have better results with that after doing typical protune type adjustments of contrast (curves) and saturation adjustments.
    As for camera matching skills and workflow I cannot help there.
    I played with some protune footage and compared against Cineform studio presets of the same footage. I compared my adjustment to those of the GoPro Cineform adjustments.
    I added
    Color Curves for contrast
    Color Corrector for saturation and overall gamma.
    Levels, a little red gamma tweak
    convolution kernel for sharpening
  • Scott Simpson
    December 11, 2013 at 3:38 pm
    Thanks for laying out a roadmap, Norman. I’ll give those elements a try.
    After posting here, I did further digging, and some of that also made me suspect the Color Curves would hold part of the solution — much like using the Technicolor Cinestyle requires the s-curve in Curves to bring the clips back to normal.
    I’ll try your recommendations.
    I may also give the GoPro studio software another look — I went straight from import to convert, but there’s an optional step in the editing section to tweak the white balance and other options before converting. I might save myself some later work if I can bake the desired changes into the file before the mp4 -> avi expansion.
  • Norman Black
    December 11, 2013 at 7:38 pm
    GoPro Studio has some presets, one called protune. That preset takes a protune file and basically make it look like a normal GoPro video. Not terribly useful since the whole reason for using protune is to customize the contrast curve to the situation instead of something canned.
    Still that preset is something I used to compare my vegas adjustments to the protune file against a GoPro standard. Actually I did not try to match exactly and I liked my tweaks better as they were custom to the scene.
    GoPro studio does not have a curves tool for contrast adjustment. Just a contrast slider.
  • Scott Simpson
    December 11, 2013 at 8:25 pm
    If I were to do it again, which I might in the future, I’d just choose a basic setting. If my goal had been to create a spectacular first-person video of a breathtaking moment, I’d want maximum flexibility for fine-tuning the image. In this case, I just wanted another angle to cut in with the other shots…..protune camraw 2k might have been a little bit of overkill for what I was after. You live, you learn.
  • Scott Simpson
    December 16, 2013 at 8:25 pm
    FWIW, I tried the effects chain you suggested… still couldn’t get a handle on the white balance being so off. Brought it into the GoPro app instead and made my changes there. The ‘Temp’ slider took me right to where I needed to go, and I was able to adjust contrast, exposure, sharpness, etc., as needed. I’ve then exported that to the high-bitrate Cineform AVI for cutting in Vegas.
    This may sacrifice some flexibility for the next step in Vegas, but it takes me 98% of the way toward where I needed to get, and I won’t have the overhead of the Vegas filters weighing on me as I edit.
    Thanks a ton for your help. I hope this thread may be useful for someone with a similar question in the future.
