Activity Forums Apple Final Cut Pro Legacy correcting flare/hot spot in frame inside FCP
  • correcting flare/hot spot in frame inside FCP
    Posted by Arthur Luhn on May 11, 2007 at 8:21 pm
    Hello,
    I have a clip in the timeline that is a CU of an actor wearing sunglasses, who inadvertly looks across where a PA is holding up a large shiny reflector, and that reflects in the sunglasses, causing hot spots.
    Is there a way to correct this inside FCP? This movement is about 60 frames long.
    Original Idiot
    Steven Lambion replied 19 years, 4 months ago 3 Members · 2 Replies
  • Tom Meegan
    May 13, 2007 at 3:02 am
    Probably not.
    You could play with layering the video, creating a very focused matte, maybe patching some pixels from another part of the glasses over the bad section, but using FCP for this sort of task is like using a spoon to cut cheese. You may achieve the basic goal, but it will take longer, and be a bit sloppy.
    This would be more properly handled in After Effects or even better, Shake. It will take some know how and time to accomplish convincingly.
    Best,
    Tom M
  • Steven Lambion
    May 14, 2007 at 10:12 pm
    Well first I would use the Color Correction Filter to patch it up a bit, then like Tom said, use layers and compsite the Tracks.
    If you have Color or Shake use them.
    Hope this helps.
    Video Specialist
    Apple Developer
    Owner of GranitWorks
