Activity Forums Apple Final Cut Pro Legacy correcting darkness around eyes
  • correcting darkness around eyes
    Posted by Ron Guilmette on October 8, 2010 at 7:30 pm
    What would be a way to fix some shadow problems due to a poor lighting
    situation?
    I have a guest speaker at a podium and the lights were positioned more on top of the person because he was leaning over the podium which created darkening around the eyes and facial features.
    I tried to follow a tutorial here on CC on fixing exposer in 3 way color correction, but the version on FCP they were using was an older version so some of the steps I could not follow.So I could not get to the same result.
    I just want to lighten up the dark areas with out effecting the rest of the frame.
    I have the lastest version of FCP.
    Ron Guilmette replied 15 years, 10 months ago 2 Members · 2 Replies
  • Rafael Amador
    October 9, 2010 at 1:10 am
    Google “Final cut marcus plugins” or “Final Cut Haiku Face light”.
    rafael
    http://www.nagavideo.com
  • Ron Guilmette
    October 12, 2010 at 12:38 pm
    When I follow the directions to install the plugins the path is different when I try on my machine. I can not find final cut system support>plugins. Also how do I unzip the files on a Mac?
    I am on a newer Imac.
    Here are his directions.
    Once downloaded the plug-ins need to be unzipped and put in the plug-ins folder (Library>Application Support>Final Cut Pro System Support>Plugins).
    These plug-ins will appear with the Color Correction filters.
    Thanks for your help.
