Activity Forums Apple Final Cut Pro Legacy Correcting Crunchy/Bassey audio!
  • Correcting Crunchy/Bassey audio!
    Posted by Aryn Leigh on August 9, 2011 at 3:32 pm
    Hi there,
    We recorded a debate recently (multiple lavs and a dynamic from the audience) and the audio mix that was fed into our camera has major distortion issues. We’re dealing with a low rumble that happens as a result of a mic rubbing against someones shirt- and also, an over-sensitive dynamic mic that caused clipping during an interview question.
    During playback we were able to fix some of the bass issues by lowering the EQ on the mixer, but is there a filter in FCP or Soundtrack Pro we can put on to correct these problems without having to re-digitize?
    Thanks in advance!
    Michael Gissing replied 15 years, 1 month ago 3 Members · 2 Replies
  • Mark Suszko
    August 9, 2011 at 4:20 pm
    People like to use the free utility called Levelator, but this is mostly to balance out levels that vary widely over a long program and are tedious to ride manually. Still, you might want to try it, it is free and works very fast with adrag-and-drop action, much like an audio version of Mpeg Streamclip, only not as multi-functioned.
    If there was a real, easy answer to your problem, somebody would be rich from marketing it and we’d all know about it already and use it.
    You might try downward expansion on the rumbles, applying parametric EQ, some compression and gating and limiting on the noise, but when you start with bad raw material, you really can’t make it good, only perceptually less bad. And the amount of time this is going to take you will be significant.
    The COW pro audio forum would have better specific suggestions for you, but my guess is their number one suggestion will be to not stint on the expense of having someone competent with the right tools doing the audio job in the first place. I’m truly sorry that’s not a helpful answer for your immediate problem. Every project failure I’ve ever had was pretty much based on this failure; not spending nearly enough time and money getting the audio right from the beginning. Audiences forgive bad lighting and camerawork, but they will NOT sit still for bad audio.
  • Michael Gissing
    August 10, 2011 at 8:14 am
    Not a job for Levelator in my opinion. Fist thing is to set good EQ. Start with a high pass filter to knock most of the signal below 150hz out. Then tune a parametric EQ with a fairly narrow Q (higher Q number = narrow notch) and sweep the frequemncy up with + gain. YOu shpuld easily hear where certain frequencies take of. Apply – gain to fix.
    Clipping distortion can be partially fixed with iZotope declipper. iZotpoe also have an excellent denoise and spectral repair modules that may also help with the rumble issues.
