Activity › Forums › Apple Final Cut Pro Legacy › Correcting Color
  • Scott Sheriff
    November 28, 2009 at 5:23 am
    Add a second (or more) 3WCC filter. You can also stack your clips in a second (or more) video track to improve density.
    It’s easier to fix underexposed video, than overexposed video, but there are limits.
  • Russell Lasson
    November 28, 2009 at 6:26 am
    If you try to raise it too much, you’ll introduce quite a bit of noise. I’ve had good success using Neat Video’s Noise Reduction plug-in. It helps a lot.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • David Roth weiss
    November 28, 2009 at 6:46 am
    Andrew,
    As they say, “a picture is worth a thousand words.” Why not post a still frame using the Cow’s tools for doing so, that way you can get precise professional help instead of guesswork. If you learn to use the tools here and get in the habit it will become second nature to you and you’ll find that many of us who do this stuff all day for a living can show you a thing or two that would otherwise take you months or years to perfect by trial and error.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Rafael Amador
    November 28, 2009 at 9:26 am
    Hi Andrew.
    To make a video lighter,
    You have to play a bit with Blacks and Highlights, but the key are the Middles (Gamma).
    Rise the gamma and compensate the Blacks and Highlights.
    Cheers,
    Rafael
    http://www.nagavideo.com
