Activity Forums Adobe Premiere Pro Correcting audio sync issues, including subclips
  • Correcting audio sync issues, including subclips
    Posted by Damon Muma on April 24, 2010 at 5:16 am
    Whenever I capture the audio seems to be off by some random amount.. I’m consigned to that for now. I just want to know the best way to work around it.
    I’m doing a lot of keying so I’m mostly working in after effects, I want to displace the audio by a set number of seconds or something like that and have it affect all the automatically created subclips.. is there some way to do that without re-encoding everything?
    Thanks for reading!
    Vincent Rosati replied 16 years, 5 months ago 2 Members · 1 Reply
  • Vincent Rosati
    April 25, 2010 at 11:23 pm
    If you get a chance, fill out your profile with your system spec’s so we can see what you’re working with.
    Generally, FireWire captures don’t have sync issues. They usually pop up when you are doing an analog capture.
    What is your hardware and workflow.
    Obviously, it’s better to fix the issue than it is to have to spend time syncing your files.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
