Activity › Forums › VEGAS Pro › Correcting a vegas audio track in Sound Forge
  • Correcting a vegas audio track in Sound Forge
    Posted by Gabriel Solomon on March 10, 2013 at 3:34 am
    I have some video footage with less then perfect audio. (The video and audio are synced) When I right click on the audio track, I have the option to open the track in Sound Forge. I corrected the audio in sound forge. How to I re-save the corrected file in sound forge and then get the corrected version into vegas.
    Gabriel Solomon
    LifeCapture Images
    http://www.lifecaptureimages.com
    John Rofrano replied 13 years, 6 months ago 4 Members · 4 Replies
  • Bob Peterson
    March 10, 2013 at 4:51 am
    File -> Save. It will be in Vegas when you exit Sound Forge.
  • Gabriel Solomon
    March 10, 2013 at 4:59 am
    That was obvious and I tried that, and it wasnt able to save. What format should i specify it should save to? My original video file is m2ts
    Gabriel Solomon
    LifeCapture Images
  • Mike Kujbida
    March 10, 2013 at 5:43 am
    [Gabriel Solomon] “When I right click on the audio track, I have the option to open the track in Sound Forge”
    You should also have the option to “open copy” and this is the preferred method.
    Do your desired editing, save it and go back to Vegas.
    You’ll see that the modified audio has been added as a Take over top of your existing audio event and saved to your project as Project Name Take 2.wav
    You can switch back and forth from source to new audio by clicking the audio event and pressing the T (for Take) key.
    The beauty of using the Copy mode is that your source audio is untouched.
  • John Rofrano
    March 10, 2013 at 1:22 pm
    [Mike Kujbida] “You should also have the option to “open copy” and this is the preferred method.”
    This is important. Also, on subsequent edits you can then just “Open” because you’ve already made a copy unless you want to build multiple takes so that you can select between them.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
