Activity › Forums › Canon DSLR Cameras › Correcting 7D Camera Mic Audio
  • Correcting 7D Camera Mic Audio
    Posted by Bill Brownstein on February 17, 2011 at 8:29 pm
    I just finished shooting a documentary and we had a malfunction with our H4N/Boom setup so I’m going to need to use some of the camera mic audio from the 7D.
    It actually turned out really well; you only hear negative things about it but it’s actually an exceptional little mic they have in there. Only problem is everything has a really sharp, crispness to it. If I could soften that up just a little bit and remove some background sound, I think this could work.
    So has anybody done this? And if so, what kinds of adjustments/tools did you use? Or does anybody know of any resources out there for this specific sort of adjustment?
    Thanks!!!
    Bill Brownstein replied 15 years, 7 months ago 2 Members · 2 Replies
  • Brian Deviteri
    February 17, 2011 at 10:21 pm
    You should start with ProTools – there is a plugin called X-NOISE that is pretty much phenomenal for eliminating some BG noise. In all honesty, if it’s terrible BG noise and it’s mixing with the frequencies that your “needed” audio is in (assuming vocal) then you’ll be disappointed with the results.
    Other tools to consider: Adobe Audition or Adobe Soundbooth. The “heat map” view for EQ is great for eliminating individual frequencies, but I personally find it slightly difficult to do a gradual smoothing sometimes.
    For softening, you’re going to have to mix with it and test. It all really depends on the actual recorded audio – no two clips are ever the same it seems…
  • Bill Brownstein
    February 17, 2011 at 10:31 pm
    I’ll give ’em a try!
    Ha, was kinda hoping somebody at some point needed to do the same and had a workflow/presets that I could just copy. What’s wrong with these tracks is exactly the same across them all; I need to dampen the effects of the mic itself.
