Activity Forums Adobe After Effects Correct workflow when working with Linear DPX files
  • Correct workflow when working with Linear DPX files
    Posted by Chris Huggett on March 28, 2007 at 11:51 am
    Hi guys
    Im doing my first DPX job in AE7 and i would like any information on the correct process to get my job back out to DigiBeta
    The footage is greenscreen footage shot on 35mm.
    It has been scanned and provided as Linear DPX files.
    I have read Stu Maschwitzs site regarding Linear work profiles, but im getting lost.
    Heres what i have done:
    Project settings are 32 bit with the Linear sRGB preset. I have applied the colour converter to my images with the input settings as sRGB and the output as Project Working Space.
    I then apply my kelight filter, and will be then attempting to colour grade and composite.
    I hope this has been correct so far. Im then abit lost as to how to render out for regular SD vision.
    Furthermore, do i need to adjust my “proof set up” to kodak and check my proof colours.
    What does the littel spiral icon mean on the bottom of the composition window. Will this affect my output or just the viewing of it on the monitor.
    Thanks for any suggestions
    Chris
    Darby Edelen replied 19 years, 6 months ago 2 Members · 1 Reply
  • Darby Edelen
    March 28, 2007 at 4:55 pm
    [Chris Huggett] “What does the littel spiral icon mean on the bottom of the composition window. Will this affect my output or just the viewing of it on the monitor.”
    This one I can answer… That’s an exposure control that appears when you’re working in 32bpc. It allows you to look at HDR footage in varying exposures, 0 is the default. I actually don’t know if it affects the output off the top of my head, but I’m sure you could do a very quick test render (even a frame) to find out.
