Correct workflow – Libraries or events?
Hi everyone and thanks for looking,
I’ve recently moved from Premiere to Final Cut X and to be honest, I couldn’t be happier. I’m slowly getting used to the new ‘concept’/’philosophy’ and so far so good.
I do however have a doubt that will probably define the way I work with the software so better get it right from the beginning.
I run two different video businesses with two different names. My initial idea was to create two Master libraries (one per business) and then create events per job i.e.: I get 25-30 weddings/year then I would get 25-30 events within that particular library. And the same for the other business. Is this paradigm alright? Only asking because I just realised that everytime I open one event this will open the whole library and the questions is:
Will this affect FCP performance to have all those other unused events on memory? is there a way to hide these events (it becomes a bit too many messy on the left side of the screen with all these events piling up!!)?many thanks,
