Activity Forums Adobe After Effects Correct workflow for dealing with around 100 rotoscoped video layers?
  • Correct workflow for dealing with around 100 rotoscoped video layers?
    Posted by Eran Amir on August 3, 2013 at 11:51 am
    Hello Everybody!
    I am looking for the best way for compositing around 100 rotoscoped layers.
    What I want to acheive is similar to this effect:
    https://www.youtube.com/watch?v=EhgYrY8fN-0
    I tried to test with 10 layers of HD video in an AE composition,
    but very quickly I realized that is definately not the way to go.
    What would be the most reasonable way to create such a composition?
    Eran.
    Roland R. kahlenberg replied 13 years, 1 month ago 4 Members · 5 Replies
  • Darby Edelen
    August 3, 2013 at 10:25 pm
    [Eran Amir] “I tried to test with 10 layers of HD video in an AE composition,
    but very quickly I realized that is definately not the way to go.”
    Why did you come to that conclusion? Performance reasons or was execution difficult? It would help to know what issues you’re trying to avoid.
    Darby Edelen
  • Eran Amir
    August 4, 2013 at 2:09 am
    [Darby Edelen] ” Performance reasons or was execution difficult? “
    I think it’s both reasons together… Rotoscoping took extremely long or didn’t react at all because it was so slow. And I couldn’t get the thing to render without AE choking. I think using the original video footage was too much, or?
    Eran.
  • Michael Sisko
    August 4, 2013 at 12:25 pm
    In the piece you linked to I would have used layer masks for all the aircraft. Rotoscoping is very intensive on both your time and and your machine. How are you trying to render, full Animation codec will be a massive file and most likely choke. Try running each as a precomp after you rotoscope it. Also make sure when you start rendering you clear your ram cache. This will impact your render ability since rotoscope uses a lot of ram.
  • Eran Amir
    August 4, 2013 at 1:27 pm
    Yeah, rotoscoping is no doubt my biggest challenge.
    Problem is I am not using planes in my project,
    so unfortunately I will have to rotoscope intensively and not use layer masks.
    Eran.
  • Roland R. kahlenberg
    August 8, 2013 at 1:27 am
    Look at using mocha for your rotoscoping tasks. mocha is exceptional for tracking-assisted rotoscoping tasks.
    Further, there seems to be an issue with terminology – rotoscoping also means masking if you’re masking to create articulated mattes.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
