Activity Forums VEGAS Pro Correct settings for Blu-ray(Europe)
  • Correct settings for Blu-ray(Europe)
    Posted by Rick Hughes on October 19, 2015 at 3:37 pm
    I have been editing up a number of projects … not committed any to Blu-ray disk yet.
    What is the correct or most optimum render settings for Blu-ray.( For Europe & Oz)
    At front end the projects settings options give:
    1920 x 1080 with frame rate of 23.976 (IVTC film) 25 (PAL) or 50 (Double PAL)
    The render options are 1920 x 1080 24p 1920 x 1080 50i or 1920 x 1080 60i
    My sources are not interlaced. I am sort of convinced that for modern Blu-ray players & 1080p TV’s then I should stick with 1920 x 1080 24p, until searching here I found this comment:
    Yes, PAL countries should use 1080-50i and NTSC countries should use 1080-60i.”
    I also tried Sony web site and it states:-
    In the Vegas or Movie Studio “Render As” window, select MainConcept MPEG 2 as your format. Then select Blu-ray 1920×1080-60i, 25 Mbps video stream template (select 50i if you are in Europe).”
    Why use interlaced ? … if playback is on a full HD system (1080p) why ?
    Probably my lack of understanding, would like to understand.
    John Rofrano replied 10 years, 9 months ago 2 Members · 4 Replies
  • John Rofrano
    October 19, 2015 at 8:38 pm
    [Rick Hughes] “Why use interlaced ? … if playback is on a full HD system (1080p) why ?”
    Because Blu-ray is an interlaced format for backward compatibility and if you want to deliver PAL Blu-ray you should use 1080-50i. This will not make a bit of difference in the quality of your image because both fields will be from the same progressive source frame. It’s just how Blu-ray is.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Hughes
    October 19, 2015 at 9:53 pm
    Thanks … that’s what I’ll use then.
  • Rick Hughes
    November 16, 2015 at 6:14 pm
    John .. been following this advice … and used the MainConcept 1920×1080, 50i template … but maybe I did not use it correctly.
    If I try to render this with frame rate at default (50) it fails with ‘an error occurred while creating the media file
    If I set it to 25fps it Renders OK.
    I also tried 50fps and set it to progressive – fails with same error message.
    What should I be using here? Goal is a Blu-ray compliant 1920×1080 … and assumed for best HD this should be 1080p.
  • John Rofrano
    November 18, 2015 at 12:55 pm
    [Rick Hughes] “John .. been following this advice … and used the MainConcept 1920×1080, 50i template … but maybe I did not use it correctly.”
    That’s right. You set the frame rate to 50 and Blu-ray only supports 25 fps. You need to use the Blu-ray templates without changing anything except maybe the bit rate if you want them to remain compliant with the spec.
    ~jr
