Activity Forums DaVinci Resolve Correct Qualifier behavior?
  • Correct Qualifier behavior?
    Posted by Tobias Heilmann-schuricht on November 19, 2014 at 8:14 am
    I am observing the following, grading r3d footage in LOG Space.
    Using the Lift wheel I am crushing the blacks down to the “0” line on the waveform (and beyond).
    Now I want to use the LUM qualifier to avoid touching the darkest areas.
    I raise the Low Clip threshold, however I am not seeing anything happen in the blacks until I have raised the threshold to a Low Level of 52.
    Is this normal? And is so, why? Why would the threshold not be much closer to “0”?
    Thank you as always… Tobias
    In Touch Media GmbH
    Germany
    Marc Wielage replied 11 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • Margus Voll
    November 19, 2014 at 9:45 am
    Are you doing the key in serial or paralel node?
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Tobias Heilmann-schuricht
    November 19, 2014 at 1:00 pm
    Serial
    In Touch Media GmbH
    Germany
  • Margus Voll
    November 19, 2014 at 1:19 pm
    Then you should be able to get proper key.
    HAve you tested different modes HLS, rgb etc. ?
    Margus
    Resolve 11
    BMC 2,5k
  • Marc Wielage
    November 20, 2014 at 3:39 am
    I wouldn’t worry about the numbers. Just worry about the results you see on screen and on the scopes.
  • Juan Salvo
    November 20, 2014 at 4:13 am
    It’s normal. As I pointed out last time someone asked this, the qualifiers works in float space, and let’s you differentiate below black and over white values, as well as visible values.
    https://JuanSalvo.com
    https://theColourSpace.com
    November 21, 2014 at 8:12 am
    Ah, ok… thanks. In the end, yes, I just looked at the results. Would the Offset also influence where the key starts to work?
    In Touch Media GmbH
    Germany
  • Marc Wielage
    November 22, 2014 at 12:58 am
    I wouldn’t touch the Offset if the basic picture looks good. Adjust the qualifiers to match the picture; don’t move the Offset to change the qualifiers. Ignore the numbers.
    November 26, 2014 at 1:56 pm
    Why do you stay away from the Offset?
    In Touch Media GmbH
    Germany
  • Marc Wielage
    December 4, 2014 at 5:15 am
    Offset can work in some situations. It all depends on the nature of the initial photography and exposure. There are very few absolutes in this business.
