Activity › Forums › Adobe Premiere Pro › Correct project settings for 16mm scans?
  • Correct project settings for 16mm scans?
    Posted by Peter Humble on April 9, 2019 at 12:39 am
    I’m working with 16mm source scanned as a tiff image sequence for the first time and wondering how I should set up my project. A bit confused about the frame rate amoung other things.
    Should my project frame rate be 24fps given film is 24fps?
    But then if I’m finishing on video don’t I need to encode it at 25fps? (PAL region)
    By the way I’m working with an old CS6 version on a Mac.
    If anyone could set me straight on this that would be great.
    Chris Wright replied 7 years, 5 months ago 3 Members · 5 Replies
  • Chris Wright
    April 9, 2019 at 1:00 am
    you’d have to determine what the native film frame-rate was, since you’ll be choosing between odd looking speed changes or optical interpolation.
  • Peter Humble
    April 9, 2019 at 1:07 am
    The film was all shot at 24fps
  • David Roth weiss
    April 9, 2019 at 6:24 am
    It was shot at 24fps, but was the image sequence shot 1 to 1 with any pull down, etc.?
    It’s never as easy as you think, “most of the time.”
    I’m going into a no cell zone, so y’all are on your own to sort out this mini-mystery.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Peter Humble
    April 10, 2019 at 1:31 am
    Ok…..It was scanned 1 to 1….no pull down.
  • Chris Wright
    April 10, 2019 at 3:27 am
    where’s it going to? DVD? PAL can playback NTSC 23.976 stuff, web, doesn’t matter.
