Activity Forums DaVinci Resolve Correct method for joining clips?
  • Correct method for joining clips?
    Posted by Chris Jones on May 3, 2012 at 4:11 pm
    What is the correct method for joining two clips in the timeline? (I know where the command is. Just not the best way to use it)
    I thought it would be to select two clips at the same time then EDIT/JOIN CLIP. But that didn’t work.
    I then picked one clip and and hit “join clip” and it worked… and it applied the correct grade to the other clip – which was nice… but I basically just got lucky with that.
    What is the correct procedure for joining clips? I couldn’t find it in the manual.
    Also is it possible to join a number of clips all at once?
    Chris Jones replied 14 years, 4 months ago 2 Members · 2 Replies
  • Juan Salvo
    May 3, 2012 at 4:37 pm
    If you want to apply the same grade to multiple shots, the correct method is to use groups. It’s covered in the timeline chapter of the manual.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Chris Jones
    May 3, 2012 at 5:03 pm
    I was actually trying to join 2 clips – the grade applied to the correct clip was just a fortunate byproduct.
    I had split up a takes from a 5 min clip. But found after grading I had split a clip in the wrong spot and was trying to join it back up.
    I’m not sure if I should always place the playhead at the end of the clip nearest to the one I want to join; always use the second clip; select one clip, then place the playhead over the other clip and click “join clip”, etc. It also seems there is a way to control which grade is applied to which clip.
