Activity Forums Sony Cameras Correct frame rate
  • Correct frame rate
    Posted by Digital Antics on May 25, 2007 at 1:48 am
    I am working on a shoot and some of the b-roll we will be using is some animation that has been rendered at 60i. We are shooting some interviews with the F900R and need to figure out what frame rate to shoot at in order to cut seamlessly between the interview and b-roll. We really don’t want to shoot 59.94. Is that our only option or could we get away with shooting 29.97p. And we really can’t re-render the animation. Anyone have any thoughts?
    Steve Wargo replied 19 years, 4 months ago 2 Members · 1 Reply
  • Steve Wargo
    May 25, 2007 at 5:53 am
    Why not shoot the interviews at 59.94 (60i)? There won’t be a noticable difference between that and 29.97. With motion, you might be able to tell because of progressive instead of interlaced but interviews won’t give it away. If you want them to look different, use filters or a gamma setting.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
