Activity Forums Blackmagic Design Correct FCP Device Settings for Panasonic AJ-D960 + Blackmagic
  • Correct FCP Device Settings for Panasonic AJ-D960 + Blackmagic
    Posted by Neil Ryan on November 28, 2005 at 3:14 am
    Can someone please confirm the correct device control settings in FCP when using a Panasonic AJ-D960 with PAL video.
    Is it a matter of copying the ‘Blackmagic PAL 25Hz’ setting and changing the protocal from ‘Sony 422’ to ‘Panasonic 422’?
    Are the Capture and Playback Offsets the same?
    thanks.
    Kristian Lam replied 20 years, 9 months ago 2 Members · 1 Reply
  • Kristian Lam
    November 28, 2005 at 3:28 am
    When using a Panasonic deck, you should switch the protocol from Sony to Panasonic.
    [Post Man] “Are the Capture and Playback Offsets the same?”
    This will differ from deck to deck and even decks of the same make may have different offsets. You should experiment with capturing and playback to your deck to find its offsets. The default settings is a good starting point.
    regards
    Kristian
    Blackmagic Design
