Activity Forums Adobe Premiere Pro Correct Export Settings?
  • Correct Export Settings?
    Posted by Christopher Joseph on June 6, 2007 at 6:11 pm
    I’m experiencing some soft picture and ghosting issues when exporting to DVD. I’m assuming my export settings are wrong.
    The project is DV 720×480, 16×9, 24p(A). What should my export settings be (assuming I want the highest quality video)? The project is a 30 second spec commercial so space is not an issue.
    Any and all detailed help and explanations are greatly appreciated.
    Delete replied 19 years, 3 months ago 3 Members · 5 Replies
  • Aanarav Sareen
    June 6, 2007 at 6:32 pm
    Premiere Pro 2.0 does have some softening problem while exporting to DVD.
    Can you post a screenshot of your problem?
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Christopher Joseph
    June 6, 2007 at 6:44 pm
    I’m not at home with the project at the moment but honestly, I’m most concerned with the ghosting/trailing/strobing. I’m assuming some of the softness is due in part to that which is a direct result (I’m assuming) to incorrect export settings.
    In general, what settings should I be on? Have I made a mistake by shooting 24p(A)? I was under the impression that that was the better option. I’ve shot with that setting in the past but I was on Premiere 1.5 and can’t go back to see what kind of settings I used on that project when exporting to DVD.
    Thanks for the timely response!
  • Aanarav Sareen
    June 6, 2007 at 6:56 pm
    Yes, the problems that you are seeing may be linked to incorrect export settings. Can you post in detail your project settings?
    – Aanarav
    Aanarav Sareen
    June 10, 2007 at 8:25 pm
    Editing Mode: DV 24p
    Timebase: 23.976 frames/second
    Fields: No Fields (Progressive Scan)
    Display Format: 24fps Timecode
    Capture: DV Capture
    Playback Settings
    24p Conversion Method: Interlaced Frame 2:3:3:2
    Interpret Footage
    Use Frame Rate from File: 23.976
    x Remove 24p DV pulldown
  • Delete
    June 11, 2007 at 3:43 pm
    did they get back with you on this?
    Try exporting to tif files and doing the final output from After Effects. Also you may want to check out Huffyuv codec. I think theres a freeware one floating around the net that’s pretty good for this stuff.
