Activity › Forums › Blackmagic Design › correct driver
correct driver
Posted by Rob Alexander on November 3, 2007 at 6:04 amHi,
can somebody tell me which the correct driver to use with my setup is?
OS 10.4.10
QT7.2
FCP 5.1.4
Decklink extreme
Mac G5 dual 2ghz
4gig RAMThanks
Don Jaksa replied 18 years, 10 months ago 3 Members · 3 Replies -
Kristian Lam
November 5, 2007 at 4:34 am -
Don Jaksa
November 7, 2007 at 3:54 pmI am running the same setup, but having various problems with drivers.
driver 6.4 – Analog audio and monitoring breaks up, crackles and residual noise
driver 6.5 – Same Problem as above
driver 6.5.1 – Same problem as above, not quite as bad, but analog YRB video breaks up occasionally
driver 6.6 – Audio problem fixed, video problem worse
So I guess that 6.5.1 is the most stable. But I have rolled back to 6.4 to keep video stability and have connected an AES audio output in hopes that it fixes the problem.
DJ
Don Jaksa
November 15, 2007 at 6:17 pm6.6.1 drivers seem to fix my audio and video problems. All is well in Multibridge Extreme land.
DJ
