Activity Forums Adobe After Effects Corner Problem
  • Corner Problem
    Posted by Cagdas Kara on December 26, 2018 at 7:13 pm
    Hello to everyone.
    I would like to rotate the writing in the corner. How can I easily do that?
    I use animated texts as a separate comp and as a picture on the main comp. I mean, they’re not texts.
    I hope I can tell.
    (I apologize for all my bad english.)
    Thank you.
    Regards.
    Kalleheikki Kannisto replied 7 years, 8 months ago 2 Members · 4 Replies
  • Cagdas Kara
    December 27, 2018 at 6:15 am
    Dear Dave,
    thank you for the answer.
    But I didn’t quite understand.
    I share the project.
    Can you help me with the project?
    Thank you,
    Regards.
    12979_walltext.rar.zip
  • Kalleheikki Kannisto
    December 27, 2018 at 9:47 am
    To expand on Dave’s answer:
    You need two copies of the text (image) layer, both masked so that they cut off at the corner, one showing the back wall, one the side wall.
    Make both layers into 3D layers.
    Move the anchor point of the side wall layer with the “pan behind” tool horizontally to the corner.
    Rotate the side wall layer on the Y axis until it aligns with the perspective of the side wall.
    Senior Graphic Designer
  • Cagdas Kara
    December 29, 2018 at 9:06 pm
    Dear Kalleheikki,
    thank you for your answer.
    I did trials. But I was not successful. Something’s not happening.
    Is there a tutorial video about this?
    Because I want to do it and learn.
    Thank you,
    Regards.
    December 30, 2018 at 11:54 am
    Can you do a screen grab of what you got as a result? That might clarify what went wrong.
