Activity Forums Boris FX Corner Pinning enigma – cannot rotate past 90 degrees
  • Corner Pinning enigma – cannot rotate past 90 degrees
    Posted by Michael Shaw on July 28, 2011 at 7:46 pm
    I’m using BCC Corner Pinning in MC5.5.
    The graphic is being pinned to fill a frame on an underlying track.
    All is fine until the background frame twists from horizontal (landscape) to vertical: the pinned image then flips so that instead of being turned 90 degrees, it is upright again – portrait and squished in.
    I’ve tried other graphics, other backgrounds – all do the same.
    It was suggested it was a keyfreame problem – it occurs just dragging the corners to rotate the image, withoput keyframes.
    Why? What is the cure. Is there a property I’ve missed? I cannot see one, but…
    Help appreciated – thanks!!
    Mike
    Michael Shaw replied 15 years, 1 month ago 2 Members · 3 Replies
  • Peter Mcauley
    July 28, 2011 at 8:15 pm
    Hi Mike,
    I just reproduced the issue on my system. Very odd alright – I’m not sure why this is happening or if this is something that is under our control but I’ll bring the issue to engineering and ask.
    Meanwhile, as a workaround, you might want to pre-rotate the image using BCC DVE, then use the BCC Corner Pin filter to pin the rotated result.
    Cheers,
    Peter.
  • Michael Shaw
    July 28, 2011 at 9:07 pm
    Thanks Peter. I’ll try what you suggest (but I have to admit – I am very new – and raw – with MC and BCC effects). I wonder if rotating the image first will work though – I actually need t rotate the picture (the background frame is being turned around) through nearly 180 degrees. I had thought of reshooting the sequence – but the logistics of it all … and the continuity breaks …
    Perhaps using rotate in conjunction with the corner pinning …
    Mike
  • Michael Shaw
    August 2, 2011 at 9:52 am
    Peter – I found an alternative effect with Corner Pinning as a feature which works OK – Avid ‘Blend’ effect – and I’m using that at the moment.
    However, BCC Corner Pin would be better for future use – will there be a patch to correct the problem? If so, would it be possible to let me know when the patch is available? Thanks.
    (I think I am one version behind (6) the current version btw – so hopefully that version would be patched as well – assuming V7 exhibits the same problem…!)
    Mike
