Activity › Forums › Adobe After Effects › Corner Pin, pixelate.
  • Corner Pin, pixelate.
    Posted by Matthew Wheeler on April 26, 2010 at 8:52 am
    Hi there,
    Got a small question about some corner pin data I exported data via mocha.It imported into after effects fine but its looking rather high quality againts the orginal HDV footage. I need to add a pixelated effect to the corner pinned data, is mosaic effect best for this? If it is i need to tie it up in an expression of some kind, linking it to a tracking data null to change the amount on zoom (scale in the null). Can anyone help me
    out with that expression. I guess there might be a better way, any ideas?
    ta
    Matthew Wheeler replied 16 years, 5 months ago 33,470 Members · 2 Replies
  • Matthew Wheeler
    April 26, 2010 at 2:28 pm
    the footage im using with the corner pinned comp is a layered/animated psd (at 100%width/hight). What i really was asking, is whats the best way to get footage to match with pixeleted verses higher def footage. match the pixel count, or at least give the impression its from the orginal footage.
  • Matthew Wheeler
    April 26, 2010 at 3:19 pm
    Thanks for your help dave. I always thought any scale/corner pinn effects would re-sample in AFX till the meets the comps native rez. I’m having trouble as its its scaling stuff and the main tracked footage isn’t raw hdv data its a h264 compression version.
