Activity Forums Adobe After Effects Corner Bug For Channel
  • Corner Bug For Channel
    Posted by Zack Florance on August 19, 2005 at 2:07 pm
    Hi All,
    I’m thinking about running a corner bug on our channel here and I don’t really know about what it will take equipment-wise to do that. Does anyone out there know what type of pc’s/software I need or perhaps someone has a recommendation for me on a good system. Thanks in advance for all your help!
    Jonathan Miller replied 21 years, 1 month ago 3 Members · 2 Replies
  • Tim Johnson
    August 19, 2005 at 5:18 pm
    I work with Newtek’s VT[4.5] on a daily basis. May be sort of overkill, but it has full animation capabilities with alpha output. Also comes with Lightwave 3D, a capable NLE, and a boatload more. I use it just for the After Effects framebuffer. You may want to check out their site (www.newtek.com) or contact their staff to see if it would be a good match.
    Tim Johnson
    KUTV 2 News
    Salt Lake City, UT
  • Jonathan Miller
    August 19, 2005 at 9:28 pm
    Check out Keywest Technology’s LogoSTAR.
    https://www.mediaxtreme.tv/products/logostar/ls200/index.htm
    It’s simple, standalone and just works. You can forget about it once you’ve set it up.
    Should be under $2000.
    You can put it as the last piece of gear in your broadcast chain, or just before any commercial insertion gear.
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
