Activity › Forums › Apple Final Cut Pro › CoreMelt has a free Source Timecode Effect for FCPX.
Posted by John Fishbackon May 30, 2015 at 7:32 pm
No more problems making source timecode burns. CoreMelt is the best! Here’s the link.
Eric Santiago replied 11 years, 3 months ago 4 Members · 6 Replies -
Jeremy Garchow
May 31, 2015 at 2:01 pmSo, I really want this to work, but be careful as I find it inaccurate at least on 23.976 media.
I know the Coremelt folks are looking in to it.
John Fishback
May 31, 2015 at 4:28 pmThanks for the heads up, Jeremy. All I did was apply the effect to a clip and see timecode. I didn’t check to see if the t/c was accurate.
Bret Williams
May 31, 2015 at 5:36 pmI found the same. And if you use it to display rec time code burn in, it gets more and more off the longer the program is. It’s more accurate with drop frame. But often 1 frame off with DF. My stuff is 29.97p I tested with.
John Fishback
May 31, 2015 at 7:36 pmPerhaps in their calculations they used 23.98 rather than 23.976 which would cause drift.
Jeremy Garchow
May 31, 2015 at 11:38 pm[John Fishback] ” I didn’t check to see if the t/c was accurate.”
I’d check your footage and see.
If it isn’t, write support _at_ coremelt dot com and tell them about it. They might ask to send over a piece of media for testing.
Eric Santiago
June 25, 2015 at 4:34 pmCrap I didnt see this post.
Ive been using it well actually I told a director/editor to download and use it on his RED project and send the TC to VFX.
None of the numbers jived and also had to issues with Absolute blah blah.
Im inexperienced when it comes to TC and only know from what REDCineX Pro spits at me.
