Activity Forums Avid Media Composer CoreAudioManager::GetNumOutputBusses() iRep->iCurrentOutputDevice is set to NULL
  • CoreAudioManager::GetNumOutputBusses() iRep->iCurrentOutputDevice is set to NULL
    Posted by Sarah Furie on September 16, 2014 at 11:01 pm
    So I can watch, edit and play my Avid 7.0.4 project timeline perfectly without a problem. I would like to watch it through my big LED TV and speakers. I plugged in the HDMI cable and my mac output speakers are set to HDMI and I can play music from the Internet and everything is hooked up correctly. However, whenever I open Avid and then plug in the HDMI or vice versa this error message pops up: CoreAudioManager::GetNumOutputBusses() iRep->iCurrentOutputDevice is set to NULL.
    The weird thing about this error is that there is only one button to press: “OK” and anytime you press it, it gives the big rejection noise. So there is nothing to do except force quit avid and restart. Everytime I try this it does the same thing.
    Is there an Avid setting I need to change?
    Raj Rodrigues replied 11 years, 8 months ago 2 Members · 1 Reply
  • Raj Rodrigues
    September 18, 2014 at 6:37 pm
    I’m having the exact same issue here when playing back transcoded material from AMA linked clips (Canon, RED and PIX). I have an external LED TV screen fed thru the HDMI on the MacPro but my audio is thru the Line Out and goes into a mixer and then to an amp and speakers.
    Still haven’t found out how to contain this other than force quitting out and re-launching.
    Tks
    Raj
