Activity › Forums › Adobe Premiere Pro › Copyright Symbol
Copyright Symbol
Posted by Stephen D. gardner on December 11, 2006 at 7:19 pmI was trying to add A copyright symbol
to a video and elements rejects the import
from Word. Is there another solution?
TYIA,
Steve GardnerStephen D. gardner replied 19 years, 9 months ago 3 Members · 3 Replies -
Craig Howard
December 11, 2006 at 7:54 pmI make them up in the Titler Window – bit of a pain but it works. I really should make one in eps format some day ‘cos I use them a lot.
Craig Howard
Shooter Film Company
Auckland
New ZealandPremiere Pro 2.0
Troy Murison
December 11, 2006 at 8:13 pmNavigate to:
Start/Programs/Accessories/System Tools/Character Map
Select the font you want in the pulldown at the top-
then click on the symbol you want and it ‘blows-up’.
Then select ‘Select’ button, then click the copy button.
That places it in your clipboard. Then paste in your
application. Some fonts don’t offer all the characters
so that may be what you are up against. If you have a
keyboard with a ten-key, you can also hold ‘Alt’ and,
using the ten-key, type ‘0169’ and release Alt- that should
give it to you as well. (I’m pretty sure it’s 0169, but
I’m on a Mac right now so can’t check!).-Troy Murison
Seattle, WA
