Activity › Forums › Apple Final Cut Pro › Copy/Pasting an edited multicam sequence into a different project creates individual clips?
  • Copy/Pasting an edited multicam sequence into a different project creates individual clips?
    Posted by Aaron Blanton on November 10, 2015 at 6:09 pm
    Hey, folks!
    So, here’s my situation: In one project (same library) I have a multicam sequence I’ve already cut from start to finish.
    I’m taking excerpts of said sequence and making smaller videos out of it, so I figured I could just set in & out points in the timeline, copy, and paste the selections into my new projects.
    When I do that, something odd happens: Pasting the selection breaks apart my sequence, so that each cut in the previous project pastes in as a completely individual clip– rather than staying linked together as an edited multicam.
    Note that the clips themselves are still multicams (I can drag them out to make them longer, and otherwise manipulate them the way you normally can) but I can’t get them to stay linked together when they paste in.
    Anybody know what I’m doing wrong?
    Thanks!!!
    Aaron Blanton replied 10 years, 10 months ago 2 Members · 4 Replies
  • Bret Williams
    November 11, 2015 at 1:10 am
    If I understand you correctly, I’m guessing that it’s just losing the match frame reference (dotted separator vs solid line separator) between clips. Probably just a quirk or bug. Doesn’t change any functionality except you can’t delete the edit point and would have to roll it out with t tool.
  • Aaron Blanton
    November 12, 2015 at 9:31 pm
    Yes, that’s exactly what’s happening. Good to know it’s a bug, and thanks for the workaround!
  • Bret Williams
    November 12, 2015 at 9:34 pm
    If you match frame a few clips, do they all match back to the same clip in the event, or do they create new multicam clips?
  • Aaron Blanton
    November 12, 2015 at 9:38 pm
    Yeah, they all match back to the same clip in the event. Looks like the problem’s isolated to the timeline.
