Activity › Forums › Apple Final Cut Pro Legacy › Copy/Paste: What’s up with Auto-Select?
  • Kevin Monahan
    August 18, 2008 at 7:28 pm
    Seems to work with multiple clips though. Hmmm….
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • David Bogie
    August 19, 2008 at 4:19 pm
    Kevin, odd to se you posting a question, buddy.
    I have never, never, been able to get autoselect to perform repeatably or as expected. I can cut and paste twice, without changing anything, and get completely different results.
    bogiesan
  • Tom Wolsky
    August 19, 2008 at 7:49 pm
    The default behavior is to always paste back to the same track the clip came from regardless of the current autoselect select settings. If you copy from V1 it will paste to V1, unless you make a change. So if in your parent sequence V1 is not autoselect and you copy from V1 in the nest the paste will still occur to V1. You actively have to make a change in the autoselect condition to change the paste behavior.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • David Bogie
    August 19, 2008 at 9:51 pm
    [Tom Wolsky] “You actively have to make a change in the autoselect condition to change the paste behavior. “
    So autoselect is only intrusively useless when you don’t want it to be but not when you need it to be?
    bogiesan
  • Kevin Monahan
    August 20, 2008 at 12:35 am
    But Tom, I did just that. I copied from V1 in the child sequence. Auto Select was on for V2 in the parent, but it still copies to V1. To have my Auto Select ignored seems to be that the behavior is broken to me. To have to on/off it to make it work seems to be, uh, not too elegant.
    Don’t get me started about Snapping! I hate it that it turns on automatically all the time.
    Bog, I post q’s here from time to time if I just can’t work out the problem on my own. I can always count on the interface master (Tom) to clarify the issue for me.
    Kevin Monahan
  • Tom Wolsky
    August 20, 2008 at 4:13 am
    That’s the way it works. It used to work the way you want in an earlier version, but they changed it so the default behavior was always to go back where it came from.
    All the best,
    Tom
  • Curt Casassa
    October 15, 2009 at 5:37 pm
    What exactly is Auto Select? I’m very new to Final Cut…just purchased my first Mac…could you give me an example of how it would be used?
