Activity › Forums › Adobe Premiere Pro › Copy/Paste title attributes?
Posted by Benjamin Ausmith on September 12, 2012 at 8:41 pmHey everyone. Is there a way to copy the parameters from the titler tool into all my titles? I need to change the color, font size, and leading on about 80 captions. Don’t want to do them individually. Thanks!
Benjamin Ausmith
Post-Production Assistant
Monadnock Media, inc.Matt Coleman replied 12 years, 2 months ago 4 Members · 7 Replies -
Chris Warren
September 12, 2012 at 9:05 pmYes there is. Create a new title with all the settings: color, font size, and leading
Then save it as a style. There should be a panel in the titler with a bunch of other styles to choose from (all the different colored “A”s) if you right click in there, or select the menu icon at the top then you should have the option to save as a New Style or something like that.
Or you could save the title as a template by opening the template menu, but I think saving as a style makes more sense for what you’re doing.
ChrisW
http://www.azprovideo.com -
Benjamin Ausmith
September 13, 2012 at 1:22 pmInteresting. Saves me a couple of clicks, but doesn’t apply the font size by default, nor does it seem to keep my leading. Still, better than nothing. Thanks
Ben Waflik
July 4, 2013 at 8:47 pmYeah, I’d like to figure it out too. I made a custom style, but how do I apply it to all of the titles in the sequence?
Benjamin Ausmith
July 11, 2013 at 7:08 pmOne possible way would be to do the titles in After Effects, much easier to change attributes on multiple layers.
Benjamin Ausmith
Monadnock Media, inc. -
Ben Waflik
July 11, 2013 at 7:35 pmYes, but in Ae text layers are not reflected in the project panel. So, if there’s a couple of comps with text layers, you’ll have to open them one by one, to change text style, same thing. BUT, one can make a big Ae comp, covering entire Premiere’s sequence, add all of the necessary texts and trim them as needed. Then you’ll have all the layers in one comp and be able to select them and apply style changes. Thanks for the idea, Benjamin Ausmith!
