Activity Forums DaVinci Resolve Copy/paste OFX keyframe animation in DaVinci Resolve Lite
  • Copy/paste OFX keyframe animation in DaVinci Resolve Lite
    Posted by Vasilis Miltiadis on May 28, 2015 at 5:13 pm
    Hi, I have a Particle Illusion OFX node, and I’ve also created a simple animation moving an emitter around. I’m facing two issues here.
    One, I want to loop the animation but I can’t find a way to copy/paste the keyframes next to each other. I can select them all with SHIFT but there’s no right-click menu, and CTRL-C/CTRL-V doesn’t do anything. I could of course copy the node, but that makes the emitter restart, and spoils the effect I’m after.
    The second issue I already wrote about in the Particle Illusion forum here, but since I don’t know if it’s a Resolve quirk, I’ll outline it here as well. The emitter doesn’t react to the movement like in the preview window, it leaves no trail behind, and it doesn’t bend at all.
    Any ideas?
    Vasilis Miltiadis replied 11 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
