Activity Forums Adobe After Effects copy/paste mask distortion
  • copy/paste mask distortion
    Posted by Antony Buonomo on October 20, 2005 at 11:19 am
    Every time I copy a mask from one layer and then paste it back into another it distorts from the original. The distortion is non-unform; typically a little wider in some places, taller in others. I thought it may be because they were 3D layers, but turning 3D off makes no difference.
    It even occurs going from Illustrator into AE. I take a background map of the UK (a bitmap) that i have in my AE project, import into AI, draw the mask and then copy/paste back into my AE layer. Even though it’s sized from the same source (the bitmap) when it goes into AE it’s a different size.
    What am I missing?
    A
    Antony Buonomo replied 20 years, 11 months ago 2 Members · 2 Replies
  • Matthew Daday
    October 20, 2005 at 1:12 pm
    Check to see if you are working in a square pixel comp. Then make sure your footage (the bitmap) is set at square pixels as well. See if this works out.
  • Antony Buonomo
    October 20, 2005 at 2:58 pm
    Thanks Mathew
    I am using non-square but surely this wouldn’t matter if I was copy/pasting layers within the same comp? And if it is the non-square pixels, this can’t mean I have to avoid widescreen? Anyone know a workaround?
