Activity Forums Apple Final Cut Pro Legacy copy/paste keyframes in FCP
  • copy/paste keyframes in FCP
    Posted by Alan Lacey on April 25, 2010 at 5:04 pm
    Sorry I can’t find much info on this via searching.
    I’m not a big user of FCP but have been using it for a long time now. To copy & paste keyframes in the motion tab I’ve always created a new keyframe then copied/pasted all the required parameters individually.
    Surely there’s got to be a better way than this?
    Cheers
    Alan (uk)
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
    Matthew Miller replied 15 years, 11 months ago 7 Members · 12 Replies
  • 12 Replies
  • Kevin Monahan
    April 25, 2010 at 5:46 pm
    Copy the clip then Edit > Paste Attributes. It doesn’t work the way you want it to (a la AE or Motion).
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Alan Lacey
    April 25, 2010 at 6:01 pm
    Thanks kevin, I saw this posting of yours when I searched previously. Don’t think the method helps much though.
    Say I just want to dupicate a position and scale keyframe further up the timeline to pause a motion how would I go about doing that using your method?
    Thanks for your patience
    Alan
    G5,MBP,Vista64,XP
  • Kevin Monahan
    April 25, 2010 at 6:15 pm
    Set Start position keyframe. Set keyframe to hold in place or freeze. Set second keyframe to hold in place. Set the final keyframe for position.
    Select Clip
    Copy Clip
    Select destination Clip
    Check box for Basic Motion
    Click OK
    Done.
    Kevin Monahan
  • Kevin Monahan
    April 25, 2010 at 6:27 pm
    FCP does what he wants. What’s wrong with copy/paste attributes? Since you have FCS, Motion is available and you can copy/paste keyframes just like AE, so go for it.
    Kevin Monahan
  • Matthew Bradshaw
    April 25, 2010 at 6:53 pm
    Or you could use an editing application like Avid!
  • Alan Lacey
    Thanks Kevin I’ll give it a go.
    Thanks also for your input Dave. I have AE and of course Motion but for such a simple thing either would be overkill. I don’t think I’m asking the earth for a pro application like FCP to provide something as basic as copy/paste keyframes!
    Alan
    G5,MBP,Vista64,XP
  • Alan Lacey
    April 25, 2010 at 6:55 pm
    Or almost anything else bar FCP (iMovie and Windows MovieMaker – and I’m not ever sure about that!)
    Alan
    G5,MBP,Vista64,XP
  • Michael
    April 25, 2010 at 9:03 pm
    Alan is right. It’s a pretty basic function and FCP should have it. It’s one of those features that Avid has had forever that I really miss in FCP. I’m sure there is a reason, deep in the ancient code of FCP, that this can’t be implemented now.
    Let’s just hope that someone, deep inside the Kremlin…I mean, deep inside Apple Hdqts, is rewriting that code.
  • Steve Cohen
    April 25, 2010 at 11:50 pm
    [Michael Heldman] “Alan is right. It’s a pretty basic function and FCP should have it. It’s one of those features that Avid has had forever that I really miss in FCP. I’m sure there is a reason, deep in the ancient code of FCP, that this can’t be implemented now.
    Let’s just hope that someone, deep inside the Kremlin…I mean, deep inside Apple Hdqts, is rewriting that code”
    Yes this is a basic function, so basic as a matter of fact that the obsolete and now de-funk Live Type has the option to copy and paste keyframes.
    Apparently all of the support applications of FCS, like LiveType, and Motion have this ability except the host application.
    This is something that is very basic and there really is no sane reason why it should not be in Final Cut.
    Steve Cohen
    Supervisor of Post Production
    O2 Media Inc.
  • Michael Colin
    April 26, 2010 at 1:40 am
    I’ve been using FCP since version 1, at which time (coming from AVID) I renamed it Workaround Pro. But I love it as much today as I did in V.1, workaround warts and all, and will gladly live with the workarounds before I jump ship and go back to AVID or Premiere. (Although the Mercury Engine in Premiere CS5 is making me THINK…!)
    Yes, they’re all just tools, but, dammit, FCP has…character! AND I get the job done! Ever see something like Bruce the Yak in AVID or Premiere?
    Girding myself for the flame war….
    Best,
    Michael Colin
