Activity › Forums › VEGAS Pro › Copy/Paste between projects (?)
  • Kelly Griffin
    March 6, 2011 at 12:50 am
    I’m liking that idea… thanks Danny.
  • Danny Hays
    March 6, 2011 at 1:35 am
    I just tried it and Vegas doesn’t recognise the alpha channel automaticlly. Right click on the new uncompressed w/alpha corner bug video event on the top track of the timeline and click, Properties, and switch the alpha channel to “Straight (unmatted). Now everything but the bug is transparent.
    Oh yea, Watch out for moving busses. Danny Hays
  • John Rofrano
    March 6, 2011 at 4:01 am
    I would recommend that you use the QuickTime Animation codec for logos. This is what it was designed for and it will be a much smaller file than uncompressed AVI.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matt Crowley
    March 6, 2011 at 12:06 pm
    If the logo is a static image (not animated), you can render it as a single PNG image and use that in projects that need the logo.
    Just start a blank project using the settings you plan to use in your projects, insert your logo graphic onto a video track and get it lined up using track motion or pan/crop. Apply any required effects (shadow etc). Make sure there’s nothing else below the logo (i.e. black background).
    Then set the loop region to a single frame of the logo and Render As, select Image Sequence and use the PNG template. You’ll end up with a single PNG image that you can then insert into any project that requires the logo. This of course can be stretched out to whatever duration you want and takes the least rendering effort and disk space.
  • Randy Brown
    May 21, 2012 at 5:24 pm
    Hello Steven…
    THANK YOU so much for the tip on opening 2 instances of Vegas… I am running 10 Platinum on a 64 bit Windows 7 machine and it would not copy and paste between projects… UNTIL now!!!!!
    Thank you thank you thank you!!!!!!!!!!!!!!!!!!!!!!!!
    Randy
Page 2 of 2
