Activity › Forums › VEGAS Pro › Copying/Importing Issues
  • Copying/Importing Issues
    Posted by Chelsea Volz on April 11, 2009 at 5:41 am
    Hello.
    I am having a very irritating problem with Sony Vegas.
    1. I have rendered a small 0:40 second part of my video and am now only working with that clip (instead of many, very small, individual clips because my computer often lags during playback). Now, I keep trying to copy a little section of the clip and paste it in a video track above the original one, however, only the audio of the copied clip appears.
    2. In another project I keep trying to import an episode of a TV show (in avi format) that I downloaded. I know the clips aren’t corrupt because they play on two seperate media players.
    Any ideas?
    I work with Sony Vegas 7.0e (Build 216).
    Any my computer is a Gateway Intel(R) Core(TM)2Duo CPU T5250 @ 1.50GHz.
    Memory: 2038MB
    And I have a 32-Bit Windows Vista Operating System.
    John Rofrano replied 17 years, 5 months ago 3 Members · 5 Replies
  • John Rofrano
    April 11, 2009 at 5:07 pm
    > Any ideas?
    What codec do these files use. Most likely it’s a codec that Vegas doesn’t support.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chelsea Volz
    April 11, 2009 at 11:19 pm
    From what I can see it is avi for the video and mp3 for the audio…
    But codecs confuse the hell out of me so I may be mistaken. Is there something I can go to to check?
  • Mike Kujbida
    April 11, 2009 at 11:55 pm
    Grab a copy of GSpot Codec Information Appliance, drop the AVI on it and let us know what it says.
  • Chelsea Volz
    April 12, 2009 at 1:56 am
    I can’t run the program for more than like… two seconds without a message popping up that tells me that the program has stopped responding/stopped working…
    And also, about the copying part of my problem, I don’t understand why it won’t show up. Like, I’ve already been editing these particular clips. The only thing I did was render it so my previewer would stop lagging but the video part of the clip won’t show up at all if I try to copy and paste it onto a differnet track. Are these the same problems?
    I just don’t get how it could be the file if it was working in the original project, you know?
    Thanks alot, for all of your help though!
  • John Rofrano
    April 15, 2009 at 4:04 am
    Which program? Vegas or GSpot? Mike suggested that you use GSpot to see what codec these files are using. That is the key to solving your problem.
    Yes it could be. What format did you render to? Vegas can render to formats that it can’t edit so you must render to a format that Vegas can edit if you want to bring it back onto the timeline.
    ~jr
