Activity Forums Apple Final Cut Pro Legacy Copying with Media Manager
  • Copying with Media Manager
    Posted by Cameracad on August 30, 2006 at 3:13 am
    When a complete project is copied using MEDIA MANAGER and moved to another back-up disk, will the files be “identical” to the original? For example if the original files were DV quality…… will the same original DV resolution be maintained?
    David Bogie replied 20 years ago 3 Members · 2 Replies
  • David Roth weiss
    August 30, 2006 at 3:51 am
    Yes. However, for some unknown reason, even when the copy render files tab is checked, not all render files end up making it to the new destination. So, keep that in mind.
    DRW
  • David Bogie
    August 31, 2006 at 4:25 pm
    Yar, check and triple-check your Media Manager copy.
    If the MM copy is going to another shop, be sure to allow yourself time to provide a second copy.
    bogiesan
