Activity Forums VEGAS Pro copying transition?
  • copying transition?
    Posted by Gilles Gagnon on March 15, 2010 at 8:29 pm
    how do I copy a transition to another clip?
    I tried copy/past event attribute as seen in other posts here, but no luck. I’m pasting onto a Sony noise texture clip if this makes a diff…
    GIlles
    Gilles Gagnon replied 16 years, 5 months ago 2 Members · 5 Replies
  • Graham Bernard
    March 15, 2010 at 9:14 pm
    You need to select the Events before PEA-ing.
    Grazie
  • Gilles Gagnon
    March 16, 2010 at 12:12 pm
    Thanks for your response, however, I just tried it again and the transition is not copied.
    What I tried:
    1. I selected the event I wanted to copy the transition from
    2. did a “copy”
    3. right-clicked on the destination event and did a PEA.
    … nothing happens, no transition is copied.
    what am I doing wrong?
    Gilles
  • Gilles Gagnon
    March 16, 2010 at 12:29 pm
    AH-HA!!!!
    I found out that the transition had indeed been copied, I just couldn’t see it until I dragged the edge of the clip.
    Thanks again for putting me on the right track!
    GIlles
  • Graham Bernard
    March 16, 2010 at 12:36 pm
    You posted your reply just as I was sending my own . . .
    Yeah – my mistake. I had thought you had already made Event overlaps. I guess you hadn’t? Which does lead me on to the thought that a “user” would expect Vegas to work in the transition timing, as of the original transition AND its X-fade timings. No, you DO have to setup your overlaps OR get one of the great scripts-GUIs to make overlap option automatic for you.
    But if you are wanting Vegas to overlap when you do PEA a trannie X-Fade, then why not? Send this as a product request to SONY!
    Grazie
  • Gilles Gagnon
    March 16, 2010 at 12:47 pm
    Thanks Grazie,
    I should have been more specific. In this particular case, I had a composition for an animated lower third and wanted to apply the same transition to my 3 composited tracks (after I had adjusted the top transition to my satisfaction).
    Gilles
