Activity Forums Apple Final Cut Pro Legacy Copying to DV tape without a tape deck
  • Copying to DV tape without a tape deck
    Posted by Chris Yeo on April 8, 2008 at 5:10 pm
    Just want to say thanks in advance for the help.
    I’m currently trying to get some footage copied on to DV tape from my hard drive. However, I don’t have a tape deck.
    The question I want to ask is – is it possible to use a handheld camcorder as a portable tape deck to record the footage from my hard drive to the empty DV tape?
    If it is possible to effect such a transfer, will the edited sound be on the tape as well?
    Sorry if this sounds like a beginner’s question. I just got my hands on to FCP a few months ago and am still trying to learn the system.
    Cheers again for the help!
    Chris
    Chris Yeo replied 18 years, 5 months ago 3 Members · 3 Replies
  • Miklos Philips
    April 8, 2008 at 5:19 pm
    Depends on your camera and your available connections to the camera. If the camera can record from one of those connections then you should be able to do it.
    Point Zero Pictures
    <https://www.pointzeropictures.com>
  • Jeff Carpenter
    April 8, 2008 at 6:08 pm
    Nearly all DV cameras allow you to record in from the firewire input.
    I can’t promise that it will work, but I can promise that if it DOES work, you’ll get all your video and audio at the exact same quality as it is on the computer. Firewire simply transfers data so nothing will be lost.
  • Chris Yeo
    April 9, 2008 at 12:33 am
    How would I do that.
    I assume it would be plugging the camera in, with the connections to the computer. As I click the save to tape option, do I need to click record on the camera?
    I wish Final Cut would give some hint of this in their manual.
    Cheers for the help.
    Chris
