Activity › Forums › Apple Final Cut Pro Legacy › copying text attributes
Posted by Renee Bergan on January 6, 2009 at 8:16 pmHi
is there anyway to copy and paste text attributes like you can do with images? i’m working on a film with subtitles that we’ve created via the text generator, i want to make them all a hair bigger..can i do this anyway simply or must i go in and change each one individually. I”m working in FCP 5.1.4.
thanks
Andreas Kiel replied 17 years, 8 months ago 6 Members · 5 Replies -
John Fishback
January 6, 2009 at 9:05 pmYou can do this in the Motion tab by increasing the scale. Then paste attributes and select “basic motion” and the scaling factor will be applied. If you’re just scaling up a bit, it should look ok. You’ll have to decide if changing the font size instead is worth the effort.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kevin Monahan
January 6, 2009 at 10:07 pmI’d never scale text beyond 100%. You’ll have to do them one at a time, however, I believe there is an XML tool that may assist you out there somewhere that can help you do this.
Or: make your own.
https://developer.apple.com/appleapplications/fcpxml.html
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Arnie Schlissel
January 6, 2009 at 10:35 pm[Kevin Monahan] “I believe there is an XML tool that may assist you out there somewhere that can help you do this. “
That’s Traffic from xmedit.com.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Tom Adams
January 7, 2009 at 2:16 amhey kevin,
are you the kevin I kinda know who used to live in w. ma? if yes- hello. if no- well, hello also.Regards,
Tom Adams – Director/Owner
Reelife Documentary Productions“cool digital video stuff…not boring or dumb”
info@reelifeproductions.com http://www.reelifeproductions.com
Williamsburg, MA, USA1.4Ghz DP mirrordoor G4
OS10.4.10, 1GB memory
FCP studio2, 850GB Graid external Firewire Drives
Panasonic DVX100a & EZ1 -
Andreas Kiel
January 7, 2009 at 3:44 amHi,
Have a look at my TitleExchange – should solve your problems with a few clicks.
Regards
AndreasSpherico
https://www.spherico.com/filmtools
