Activity › Forums › Apple Final Cut Pro Legacy › copying sequence from 23.98 to 29.97
  • copying sequence from 23.98 to 29.97
    Posted by Mark Wilkinson on May 20, 2006 at 8:37 am
    this is a weird one. we have been editing a short in a 23.98 sequence and tonight we took it in
    for the sound mix. they asked that i “drop the 23.98 sequence into a 29.97 sequence” . i tried that
    but i got an FCP error message saying it couldnt handle that. so what i did was copy all the clips from
    the 29.97 sequence and paste them into the 23.98 one. this lead to some strange results. overall, the
    sequence was intact but at a few points, clips were exchanged for clips that arent in our final movie, they
    are in the project but unsused. one clip rearragned itself, sliding out of the correct timing and was followed
    by a repeat of the clip that proceeded it. very odd and im just wondering what might have caused it. we have
    to go back tomorrow so im hoping to get a clean copy out of FCP to take down with us. any ideas what might
    have caused this ?
    Mark Wilkinson replied 20 years, 4 months ago 2 Members · 2 Replies
  • Captain Mench
    May 20, 2006 at 3:17 pm
    I’d go back to the sound house and ask why they need it in 29.97.
    What is the final version of this project? Audio is audio and isn’t frame dependent. Which program are they using? I’m sure protools can handle 24fps.
    A workaround MIGHT be to lay off the sequence back to tape. Make sure you have playback set to 3.2 pulldown cadence.
    When it goes to tape it will be in 29.97 without any problems. Then, if you need to recapture it back into FCP to create a new sequence it will have the pulldown included and you can capture at 29.97. Then give that to the sound house.
    Good luck,
    CaptM
  • Mark Wilkinson
    May 20, 2006 at 6:12 pm
    they are using a pro tools sytstem so maybe they can deal with 24 fps. i’ll check. far less unnerving that going through that business last night. thanks !
