Activity › Forums › Adobe After Effects › Copying Render Settings
  • David Johnson
    May 7, 2006 at 4:20 pm
    Absolutely. I can’t tell you exactly where to find them on Macs, but the files you’re looking for are:
    Render Settings.ars
    Output Modules.aom
    To find them, maybe use the Finder to search for files with those unique extensions and/or look in the folder that is the Mac equivalent of:
    C:\Documents and Settings\Administrator\Application Data\Adobe\After Effects\Render Settings
    You should be able to copy those files to the corresponding folder on any other computer with AE installed. I’m not 100% sure of this, but I seem to recall that these files in particular can even be copied between platforms and versions of AE. Of course, you’ll ant to back up the originals first.
