Activity › Forums › Adobe After Effects › Copying Path from llustrator to After Effects
Posted by Mika1976 on November 15, 2007 at 10:42 pmHi,
i have a text in illustrator… i create outlines… i select the outlines und copy them to my clipboard… i go to after effects… i’m in a new solid… i want to paste —-
nothing happens… i know, i have to select “clipboard on quit” to “copy AICB – Preserve Path”… but i already did it 🙁
i still can’t copy path into after effects… i’m so sad
is there a tutorial to this topic?
best wishes, michaelRhett Robinson replied 18 years, 10 months ago 3 Members · 5 Replies -
Steve Roberts
November 16, 2007 at 12:16 amIs the solid selected before you paste?
Have you tried making a mask (rectangular is fine) in the solid, then selecting “mask path” (or “mask shape”) and pasting?
Mika1976
November 16, 2007 at 10:04 amoh gosh… thank you so much… some times it’s so easy 😉
but one thing: when i scale the path (in this case a letter) up, it’s getting blurred… i thought the advantage of paths is that you can scale it without any distortion???
if this is a bug, and let’s say i have created a logo in illustrator, do i have to scale it up in illustrator, paste in after effects, scale it down there… so for the possibility, i have to sclae it up in future, there is no distortion… ???
mmhh, is this a way, you do it too? what is the professional solution?
best wishes, mika
Mika1976
November 16, 2007 at 10:05 amoh gosh… thank you so much… some times it’s so easy 😉
best wishes, mika
Steve Roberts
November 16, 2007 at 2:45 pmYou need to click the “continuous rasterization” switch. Check the Help.
Rhett Robinson
November 16, 2007 at 2:47 pmHi Mika,
I think you mean when you scale up the layer with an applied mask, it gets blurry/fuzzy; yeah, that’s going to happen.One solution is to click on the “continuously rasterize” button for the layer (looks like an asterisk, just to the left of the quality setting). Or, make your mask/layer larger to begin with, and work in the opposite direction (scale down as needed).
Know in advance that some effects won’t apply to a continuously rasterized layer, and will have to at least be precomposed, and there may be other heartbreakers… but it works well on masks as well as imported vector artwork. I usually scale the material outside of AE, myself, unless it’s only going to be a fly-by of the artwork.
