Activity › Forums › Adobe After Effects › Copying old frames into the actual one… “onion” effect from Flash
  • Copying old frames into the actual one… “onion” effect from Flash
    Posted by Johannes Roth on August 1, 2010 at 7:17 pm
    Hey guys,
    lets try to explain this with an example: I create three PNGs, each showing a different letter (a.png, b.png, c.png). So these show “a”, then “b” and then “c” when imported as an image sequence.
    What I need is an effect that “blends” every old frame into the new frames. So at first I see an “a”, then the blended combination of “a+b” and then “a+b+c” instead of “a”, “b”, “c”. Fancy settings like overlay, multiply and screen would be cool, but aren’t necessary.
    –> I want to copy each shown frame into the new ones.
    It’s a bit like this “onion” stuff in flash without fading old frames out after a time:
    https://animation.about.com/od/flashanimationtutorials/qt/flashonionskin.htm
    Other example: I import a rendered jumping ball. With the effect settings that I need, it looks like the ball is drawing on the screen.
    Hope you understand what I am trying to explain.
    With kind regards
    Johannes
    Johannes Roth replied 16 years, 2 months ago 2 Members · 2 Replies
  • Steve Roberts
    August 1, 2010 at 11:15 pm
    Effect>time>echo might do.
    Echo needs to work with moving stuff. Apply it to:
    – a movie, or
    – a comp, or
    – an adjustment layer over animated still layers
  • Johannes Roth
    August 2, 2010 at 8:47 pm
    Thanks, thats exactly what I needed.
    Stupid After Effects CS3… I searched inside the effect folder called “Time”, but there also is a folder called “Zeit” (the German word for time, since I bought the German edition). Puh.
    Well, thanks a lot!
