Activity › Forums › Sony Cameras › Copying of a clip is not possible
  • Copying of a clip is not possible
    Posted by Sverker Hahn on December 12, 2012 at 3:46 pm
    I was copying the whole disk with SuperDuper when a particular file stopped everything:
    The same result in XDCam Browser and the Finder.
    XDcam Brower show that 16% of the clip is copied before this message stops the action.
    I have unlocked the files in the info-window.
    Have never experienced this before.
    TIA
    Sverker
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 13″
    Ian Cook replied 13 years, 9 months ago 2 Members · 7 Replies
  • 7 Replies
  • Ian Cook
    December 12, 2012 at 4:19 pm
    Does the file behave normally when in the camera? I.E. can it be played back from beginning to end?
  • Sverker Hahn
    December 12, 2012 at 5:52 pm
    Yes, it is played from the harddrive with XDCam Browser from start to end without problems.
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 13″
  • Ian Cook
    December 12, 2012 at 5:57 pm
    can you rewrap into FCP and then re-export a new .mp4?
  • Sverker Hahn
    December 13, 2012 at 10:51 pm
    Do you mean that the new .mp4 could replace the faulty one inside BPAV?
    I´ll give it a try tomorrow.
    But how could this thing even be possible? (No, I don´t need to know …)
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 13″
  • Ian Cook
    December 13, 2012 at 11:02 pm
    no, we’re hoping that the re-wrap into FCP succeeds and that we can then export a new file. if this works it will put a loose .mp4 on the root of CLPR. in the OTHERS menu on the camera, select CLIP–>UPDATE to register the new file and create the metadata.
  • Sverker Hahn
    January 1, 2013 at 1:55 pm
    No, I could not import the whole clip. But it is al long clip – 5 min – and I could use the first third of it. Then I plan to delete the clip and then be able to do a backup of the whole HDD. Just hopin´…
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 13″
  • Ian Cook
    January 2, 2013 at 3:49 pm
    Just checking in to see how it’s going? Let me know if we still need to try and figure out a workaround. Been offline for a few days.. Can’t tell from the above if the FCP re-wrap worked.
