Activity Forums Adobe After Effects copying multiple paths from illustrator into ae onto seperate layers
  • copying multiple paths from illustrator into ae onto seperate layers
    Posted by Keith Vickers on April 21, 2014 at 1:29 pm
    Hi all,
    I have a question.
    How do I copy paths that are on seperate layers in Illustrator into layers in AE?
    I want to use the generate stroke effect to animate a stroke along each path.
    However it gets done,I need to bring graphics from Illustrator in AE and animate.
    thanks guys
    peace
    Jason Jantzen replied 12 years, 4 months ago 3 Members · 2 Replies
  • Brian Charles
    April 21, 2014 at 3:09 pm
    Depending on which version of After Effects you are using there are different options.
    in both CS6 and CC native ai files can be imported and converted to Shape layers with all paths intact. From the Layer menu choose Create Shapes from Vector Layer. The individual paths can then have a stroke added which can be animated independently with Trim Paths.
    In any version individual paths in Illustrator can be copied and pasted one-at-a-time on to Solid layers in After Effects. A bit tiresome but doable.
  • Jason Jantzen
    April 22, 2014 at 3:06 pm
    I think there’s a script on aescripts.com that will separate the masks to individual layers as well. I usually just use Newton for that function if I need to.
    Jason Jantzen
    vimeo.com/jasonj
