Activity › Forums › Adobe After Effects › Copying motion paths from Illustrator
Posted by Hyperion on May 20, 2005 at 5:57 pmI remember when I used to copy a path from illustrator and then paste it in AE as a motion path.
Is there any way to do it between AE 6.5 and Illustrator CS?16:9
Hyperion replied 21 years, 4 months ago 3 Members · 4 Replies -
Joe Chao
May 21, 2005 at 7:09 amIt can be done well.Check you settings of Illustrator.
My name is always misread as COW……..:)
so I got this ID:
friendcao2004@hotmail.com -
Nicholas White
May 21, 2005 at 8:28 amHey,
Read here:
https://www.creativecow.net/forum/view_thread.php?threadid=780797&forumid=2&postid=111036003263396
Take care,
Nick
Joe Chao
May 21, 2005 at 3:01 pmIt’s just what I refer to.But I use a illustrator Chinese….so I was not able to describe it…:)
so I got this ID:
Hyperion
May 21, 2005 at 3:40 pmI can’t believe it !!!!
My motion paths are back!
But now that I can do it, is there a way to scale the whole motion path in a AE.
or should I work at my comp resolution in Illustrator and then copy the motion paths at the proper size?
Many thanks
16:9
