Activity › Forums › Boris FX Particle Illusion › Copying il3 files to Emitter directory
  • Copying il3 files to Emitter directory
    Posted by Francois Blawat on November 16, 2010 at 9:35 pm
    Hello,
    Maybe I’m missing something but I found some older .il3 files that I had on CD and when I copy them to my Emitter Libraries, I cannot find them by using the Load Library button within partilceIllusion. I see all the other libraries, but I cannot figure out how to activate these so they are present. I am using Windows with the latest version of pi3 (3.0.4).
    If I select Load and manually point to another folder I can load up the libary but they do not seem to be loaded up when I start pi3.
    The .il3 files that I have copied over to my c: drive are fully read/write. I removed the read only restrictions on them.
    Thanks.
    FixitMAD
    Francois Blawat replied 15 years, 10 months ago 2 Members · 2 Replies
  • Alan Lorence
    November 16, 2010 at 10:00 pm
    Are you running Vista or Windows 7? Then it’s probably not putting the files where you think it is — writing to the Program Files folder (and subfolders) puts things in another folder.
    Does anybody know if there is a way to work around this in Vista or Windows 7?
    Alan.
    http://www.wondertouch.com
  • Francois Blawat
    November 16, 2010 at 10:04 pm
    Wow, ok. Nevermind.
    I should have double-checked my directories. For some reason I had an older folder that my libaries were copied to. I have since moved them to the correct folder and now all my emitters are now showing up under the Load Library function.
    Sorry for the post.
    Thanks.
    FixitMAD
