Activity › Forums › Adobe After Effects › Copying guides from comp to comp
Posted by Mitch Temkin on July 8, 2011 at 6:42 pmAnybody know of a way to copy the guides from one comp to another – besides the obvious copying and pasting of all layers from one comp to another?
Mitch Temkin
Stig Olsen replied 11 years, 9 months ago 6 Members · 7 Replies -
Todd Kopriva
July 9, 2011 at 7:43 amWhat kinds of guides? Depending on how they’re made, you may save an animation preset for your guides and then apply it as needed to new guide layers. For I have a shape layer animation preset that I use for some guide lines.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Mitch Temkin
July 9, 2011 at 8:46 amThanks for responding so quickly, Todd.
I’m talking about the guides that you can pull off of the ruler – the ones that don’t take up layer space in the timeline.
Mitch Temkin
Brian Charles
July 10, 2011 at 7:54 pmUnlike some other Adobe Apps (e.g. Illustrator, InDesign) ruler guides aren’t live objects that can be selected for copy, paste, or deletion.
Following on Todd’s suggestion, here’s an idea:
if the guides are all the same, create an empty comp and use the pen tool to create the guide lines and use it as a nested comp.
Turn it into a guide layer to prevent the lines from rendering.
Mitch Temkin
July 11, 2011 at 2:17 amThanks Brian. A good idea, but I was hoping there was a simple way to copy and paste them ala Illustrator. I was hoping for a five-finger key command to do the trick.
Mitch Temkin
Michael Heid
September 2, 2012 at 7:07 pmI’ve got a similar need. Sad they haven’t found a less ghetto solution to copying the guides. The solution I’ve got is to duplicate the comp with the proper guides and then paste in all of the layers you need into that comp.
Mike Damian
January 11, 2013 at 9:15 pmAFter googling this same subject I found this thread. I wish there was a way to do this easily as well. One solution I found is to duplicate the comp you want to use the guides from, and then select all and delete the layers. Now you will have an empty comp with your guides in tack.
p.s. – This is a very old thread I don’t know if I am suppose to comment on old threads, but there still hasn’t been a solution so I figured I would put in my 2 sense.
