Activity Forums VEGAS Pro Copying Event FX without Pan/Crop
  • Copying Event FX without Pan/Crop
    Posted by Patrick Entwisle on April 10, 2011 at 6:17 pm
    I was wondering if there is a way I can copy the event FX and paste them into other events without also copying the pan/crop settings. I have an effect with keyframes and I have about 100 images I would like to paste the the effect into. The problem is that the images are all different sizes and the pan/crop settings squishes/expands a lot of them. It would be a lot of extra time to fix them all so I wonder if there is a workaround of some type. Thx
    Patrick Entwisle replied 15 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    April 10, 2011 at 8:19 pm
    [Patrick Entwisle] “I was wondering if there is a way I can copy the event FX and paste them into other events without also copying the pan/crop settings.”
    Unfortunately there is no way to just paste some attributes. What is needed is a context menu when you paste event attributes to select just the attributes that you want to paste.
    I would make a Product Suggestion to Sony. The more we ask for it, the better chance we will get it.
    [Patrick Entwisle] ” I have an effect with keyframes and I have about 100 images I would like to paste the the effect into. “
    Here is how you an accomplish what you want very easily:
    • Save the FX as a Filter Package. Even if it’s just one FX. This will cause it to save the keyframes.
    • Select all of the events that you want to apply this to. (hint: if it’s all of them, right-cick the first one and choose Select Events to End).
    • Open the Plug-In Manager (Ctrl+Alt+1), find your new Filter Package under Plug-Ins > Video > FX > Filter Packages and drag and drop it onto one the selected events.
    All of the selected events will have that filter package applied including the keyframes.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Patrick Entwisle
    April 10, 2011 at 8:47 pm
    Thanks John. That worked great!
