Activity Forums Adobe After Effects copying effects.
  • copying effects.
    Posted by Malcolm Desoto on August 16, 2007 at 5:35 pm
    Just want to copy some effects to another layer. Usually I either drag and drop the effect onto the new layer or hit CTRL+C, CTRL+V.
    However, this does not seem to work with an effect like CC Particle World. Is it not possible to copy some effects? If so, can I still paste all of the previous effect parameters into the new one without havinf to manually enter each value?
    Malcolm Desoto replied 19 years, 1 month ago 3 Members · 3 Replies
  • Steve Roberts
    August 16, 2007 at 5:41 pm
    With some effects, all the settings don’t come over when you copy. You need to save a favourite. (Animation menu)
  • Accountclosedduetonorealnameused
    August 16, 2007 at 5:42 pm
    seems copy/paste will not always copy all the parameters over.
    best way is to save the effect off as an .ffx and then re-apply it to your destination layer.
  • Malcolm Desoto
    August 16, 2007 at 5:58 pm
    Thank you much!
